Old 05-22-2019, 07:16 AM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
The seats are bolted thru a steel plate on the chassis below the fiberglass. You may have a series of washers between the seat and the floor that adjusts the rake of the seat front and back that you may want to take notice of. Later cars have a wire for seat belt monitors yours probably not. A great time to add a drain port at the low point of the floor under the seat too. I replaced the original bolts with studs to make the reinstallation easier from the topside. You can easily restack the washers (if they are there) on the studs and keep them in place with tape and easily put the 4 studs thru the holes on the floor. I also ran a drill thru the mounting plate holes to enlarge them slightly to ease installation. Let us know what "Treasures" you find under the seat.
Blas
SPFWiringDiagrams@Comcast.net
