Old 05-22-2019, 06:54 PM
dacobb's Avatar
dacobb dacobb is offline
Cobra Make, Engine: ERA 3018 - Lykins 289 H.O. SBF
I did not cement the carpets on the floor. The seats keep the main sections secured. The floor tunnel mats are secured with snaps. Floor mats will tend to slide around a bit and it helps to secure them in some fashion.
I ceramic coated my exhaust back to - but not including the tailpipes. I have a lot of insulation on the floor so it's not bad down there - but at stop lights the heat is going to well in over the top of the doors from the exhaust no matter what you do. My ceramic coated SpinTech mufflers read around 500 deg when I shut things down after a ride down the road. I'm not sure how much good the ceramic coating does.
I'm thinking of doing the same thing with the carpets. I'll be using thermal/sound deadening under the carpets and under the car, and am thinking of using Jet-Hot for the ceramic coating of the exhaust. They say their process reduces heat by 65% and they have a lifetime warranty.
Anyone out there used them?
The bummer is I have to get the exhaust from ERA, take it to a local exhaust shop to weld the brackets and fit the exhaust to the car, then take it all off and ship it to Jet-Hot. Then reinstall.
