Old 05-22-2019, 08:38 PM
Jim Coleman's Avatar
Jim Coleman Jim Coleman is offline
Cobra Make, Engine: 1980 Arntz, 350 'Vette & Muncie, & Jag rear
Default Jaguar XKE Rear & MGB Front Brake Line Question
Revised Post
I'm getting ready to plumb my Arntz with brake lines -- it has an XKE rear end and a MGB front end.
What I need to know is do the Girling cylinders use bubble flare lines where the lines connect?
Moss has the MGB brake lines with the female fittings I need to hook up the front brakes using a "T" from
the front brake Girling cylinder.
The also have the rubber lines that connect to the XKE rear end, and hopefully have the hard lines with the female
fittings that connect to the rubber lines. I'll need to use another "T" from the rear brake Girling cylinder.
The Wilwood pedal has a bias adjustment between the 2 cylinders.
Thanks,
Jim
