Old 05-26-2019, 05:54 PM
patrickt patrickt is offline
Originally Posted by ACHiPo View Post
Where did my short go?
Jeez. Try wiggling wires to see if you can get the fuse to blow. If you can't, then leave the ignition light disabled and the charging configuration set up so that it works without the light. If you can make it through the summer without blowing the fuse again then you can hook it back up over the winter.
