Thread: Richmond OD
  #24 (permalink)
Old 05-26-2019, 06:57 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by MAStuart View Post
Joel I don't think trans is locked in 2 gears at the same time. As soon as you would get it in 2 gears the tires would lock up or it would strip the gears out of the trans. This would happen even with the clutch pushed in. When this happens does your tires slide?
Something is going on but I am not sure of what.
Generally, any manual transmission would be trash if two gears were selected at the same time. While one gear stays selected, it would take effort to select the other gear.
Clearly, it cannot be gears that share the same hub, like 1/2 or 3/4 in this case.
Gary
