Old 05-28-2019, 04:32 AM
Ron61's Avatar
Ron61 Ron61 is offline
Steve,
You can check the coil a couple of ways. One is to remove the high voltage lead from the top of the distributor cap and turn the engine over and see if you get a really good spark to ground. Another is if you have a meter you can check the input and output voltage and also measure the resistance of the primary and secondary windings.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
