Old 05-28-2019, 05:23 AM
spdbrake spdbrake is offline
Originally Posted by Steve Gallegos View Post
ERA626, I mean the engine turns over 3 times then stops then 3 more times It will keep doing this if I keep the button pushed. I didn't start the car this morning before I checked the rotor. Everything is correct with the distributor.
If you have a 3 crank-stop, 3 crank-stop, issue its not in the ignition circuit.
Most likely in the cranking circuit.
I'd check for:
Poor connections at the battery.
Possible failing battery. See it if does it with jumper cables and the slave car running.
Headlights getting very dim during cranking is also a clue to a poor connection or failing battery.
Starter with one failed brush can also cause slow cranking.
