Old 05-28-2019, 09:38 AM
Mike_I Mike_I is offline
Cobra Make, Engine: Midstates 427 / ERA 289 USRRC
Originally Posted by Gaz64 View Post
That can only happen if not using relays for fan control.
Gary
That is correct. As mentioned in my earlier post, the solution is to either install a relay (if you don't already have one) or diode (if you don't want to use a relay) and that will solve the issue. The correct way (for several reasons) is to have your fan run through a relay.
