Old 06-16-2019, 01:14 PM
verboss verboss is offline
Registered User
Tom: Thank you for the advice Tom. Maybe I could use the smaller version of car to create the buck (fill it with Bondo, slice it and then scale the pieces of buck to the original size). Problem I have is where to get the car or blueprints I could use. There is nobody near me with FFR Cobra and I think FFR doesn’t make small model of their cars either. And if I use some generic model of Cobra even the one corresponding to the original Cobra model I can’t be sure how much it corresponds to the FFR design.
There are some 3D models (some of them maybe even same as the original) I could use them for buck and it would be relatively easy (everything made in PC). But I am worried about the compatibility with FFR. I don’t want to end up with the body which I will have to shorten/protract or to change placement of hood, trunk or door edges.
Joel: Thank you for the suggestions. That could probably work. I will either get the frame and build the buck just from the frame (but I am not sure if I will be able to visualize every detail just from frame) or if there is somebody who could model the car just from the pictures and use it for CNC file I would probably use his services.
Now little OT: I am having problems to log in. Even after first attempt to log in I got the message that I used all my tries to log in and that I have wrong username/password. So I was forced to create new account to get in and I don't know if I will be able to log in to this account once I am log out . I hope I won't have to create new account every time I want to write here . I was trying to find the solution and there have been similar problems in the past but it doesn't seem someone has solved them.
Do you know if there is something I can do? I was even tried to write to the webmaster so I hope there will be some way out of it.
Martin
