Thread: Lights
Old 06-17-2019, 09:30 AM
Dirty Harry Dirty Harry is offline
Average Guy
Cobra Make, Engine: red Shell Valley, white stripes
I have the old school floor-mounted dimmer switch setup. Once, I had a similar situation to yours. I found a connection to the dimmer switch had gotten loose to the point where it would only make contact sporadically. It was clear that the loose connection had generated some heat, too. I shortened the wire, installed a new terminal, and plugged things back together at the dimmer switch, and all was well-has worked for years now. Don't know if your setup is like this, but if so, it's worth a look.
When I said I wanted to be somebody, I probably should have been more specific...
