Old 06-19-2019, 07:12 AM
blykins blykins is offline
Take all the linkages loose from the transmission. Reset the shifter arms all to a neutral position. You can use an open end wrench to move the shifter arm shafts.
Once everything is in a good known neutral position, put the alignment pin back into the shifter and then reset the linkages to each arm.
I suspect that they are not adjusted correctly.
If that's not the case, then I would imagine there's an issue with the interlock pin that can interfere with forward/reverse shifter rail positions.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
