Thread: Mega Squirt
Old 06-19-2019, 08:31 PM
eschaider's Avatar
Originally Posted by ERA 626 View Post
will the Pro-M work with an IR intake? how?
Yes but you will need to run it in speed density mode because there is no easy way to use a MAF w/o fabricating an air box that feeds all eight stacks from a common inlet plenum.
Absent the common feed plenum I believe the original Weber equipped cars used a copper tubing sort of interconnect between the bottom side of all the inlet ports to mitigate some of the IR pulsations that play havoc with the fueling of the engine. I don't know how effective the 'fix' was in real life. Perhaps some of the Weber crowd could chime in with their experiences.
Ed
