  #40 (permalink)
Old 06-20-2019, 04:46 PM
120mm's Avatar
120mm 120mm is offline
Cobra Make, Engine: Scratchbuild, 289 FIA Replica
Hurricanes do appear to be very good, quality cars but I don't think you could come anywhere close to building one for around $30,000. I would put Hurricane and Unique closer pricewise.
I've priced it out to the nuts and bolts, using used drivetrain components, and it is "just" doable. The Hurricane is a VERY complete kit, and as long as you stay away from options, it can be done.
Originally Posted by KDubU View Post
A Factory Five MKIV will run higher than $30k even with a 302 in it. Full kit is close to $22k, then add engine, transmission and tires and I am thinking at least $34-35k without body prep and paint. Add another $7-12k+ for the latter for a finished roadster and that is without any mods that all builders do. I always say look at $45-50k+ to have complete finished Factory Five.
For FFR, you'd have to do a donor car build to come it $30k, and donor cars are becoming much, much harder to find.
The Hurricane is a more complete kit, and you could just get it in at right around $30k if you were frugal, and used a 5.8L junkyard motor, used transmission, etc....
As far as $7-12k in paint, that is completely up to the individual owner. I guarantee you that Lynn Park's "Son of Dirt Bag" doesn't have $7-12k in paint on it, for instance.
As far as "any mods all builders do" that is your opinion and somewhat hyperbolic.
