Old 06-20-2019, 05:47 PM
AndrewB AndrewB is offline
Cobra Make, Engine: ERA 3012
Well let's try an easy test. Remove the cover to the brake master cylinders box that is underneath the driver's side of the car. That's easy to do, it just involves about four or five sheet metal screws and four or five nuts. Then turn the key to the ACC position and observe that the brake lights are on without you having to touch the brakes. Now pull the red wire off the brake light switch that is on the back of the master cylinder that is closest to the frame. See if the brake lights go out.
With the key in the ACC position, the brake lights do not go out when the red wire is pulled.
