Old 06-20-2019, 06:38 PM
AndrewB AndrewB is offline
Cobra Make, Engine: ERA 3012
Alright. You now have the red wire disconnected at both the brake light switch and the trailer relay, and the lights are out. Both ends of that red wire should not show 12v+. Put a VOM on it and see if that wire is hot with 12v+.
There is no voltage on the red wire. However there is 12v on the pink wire in block #70 that the red wire would connect to if it was not pulled.
