Old 06-21-2019, 12:51 PM
Ozzie Goat Ozzie Goat is offline
Cobra Make, Engine: Backdraft SBF-302
So, if you reverse and flip the passenger brackets you can drive bolts up through the threads and in to the seat base.
The next challenge is the OEM offset holes and supports when mounting a seat that is 'square'. The drivers slider doesn't line up after attaching to the seat. Good times, BDR.
The Cobra Roadster SR seats sit higher than the flat fiberglass tubs. I'm 5'9" if you're taller you will sit higher than the windscreen. If you're mass challenged it will also be a tight fit.
Some more adapting to do, but overall they're great.
