Old 06-22-2019, 11:43 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by hauss View Post
I understand what you are saying, but a improperly machined hole, will let air into the system. I disassembled my slave and was unable to see any wear on the piston. Not sure of bore diameter but has a adjustable pin on the speedway witch I like. Do you think master cylinder could be allowing air into the system?
That's mechanically impossible, if it could suck air in, it will definitely leak fluid under pressure.
Master cylinders can suck air, depending on type/configuration.
Gary
