Old 06-23-2019, 10:29 AM
eschaider's Avatar
Ron's source is likely to be the same as the wheel you already have so, other than the difference in appearance attributable to age, the replacement wheel should be identical to the old wheel.
The Vintage wheel will look very similar but things like the cast in place lettering on the wheel will be different. Although the Vintage wheel is in fact a cast one piece wheel if someone looked at one of your original wheels and then the replacement wheel, the different cast in place lettering would be a dead giveaway.
As long as the Minilte alternative is still available I would probably go that route just for continuity.
Ed
