Old 06-25-2019, 04:14 AM
mgarrettz88 mgarrettz88 is offline
Cobra Make, Engine: LSC427
Originally Posted by bobcowan View Post
Why do you feel it needs this? Oil is heated by RPM's, mostly. Unless you're pounding it lap after lap on the road course, the oil doesn't heat up enough to worry about. On the street, a cooler tends to keep the oil too cold. It never heats up enough to do it's job properly.
Honestly, just about every ride I've seen has a cooler so I thought that was something they left off and I needed. I don't run the car on a track just street use so maybe I don't need a cooler. WOOHOO!! I will add an oil temp though as recommended by Gaz64. I'm also running Mobil 1 synthetic, for whatever that's worth. Thanks for the info fellas!
