Old 06-27-2019, 03:02 PM
my427cobra my427cobra is offline
Club Cobra Member
Cobra Make, Engine: NAF 427
I'm learning so much here as I shift through all the responses:
Cast iron cases: 1963 to 1975
Aluminum cases: 1976 to 1982
Auburn Posi: 1963 through 1967
Warren Posi : coded with a "W" suffix in 1968 through 1970 otherwise Auburn
So I'm looking at Tom's pictures of his adapter:
He appears to be using a Dana 44 rear cover (with filler plug and breather), bolted to the rear of the adapter.
The adapter appears to be fastened to the diff housing with countersunk fasteners in the Corvette diff bolt pattern.
So you use a Corvette diff gasket on the front side and a Dana 44 gasket on the back side
Am I right so far?
Greg
