Old 06-28-2019, 05:22 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by bobcowan View Post
That didn't work here in Colorado. It was not uncommon to leave the house when the temps were in mid 30's F (1-2* C). Cruising down the highway at 75mph, the oil temp struggled to get above 120* F (49* C) or so in the pan. Even if I covered the cooler with duct tape or cardboard, it still struggled.
Depends on where you measure the oil temp.
Just like a coolant temp sensor, the oil temp sensor should be mounted after the oil pump somewhere within the oil circuit, where a higher temp closer to peaks will be measured. Pan temperatures can be deceiving.
Just like a cooling system, the temp should be able to warm up regardless.
Gary
