  #22 (permalink)
Old 06-28-2019, 07:37 PM
MAStuart MAStuart is offline
Thanks Tom. I have a Kirkham center section but it need work. When its mounted there is not much room. At one time I posted pictures of it mounted and I did not have the top plate on the tower yet and they are a tight fit. I posted the picture to show why you could not mount a jag unit with a top mount. I also have a jag unit and with some custom make side mounts it would work. Thought of using a 8.8 ford but haven't tried to see if it would fit . Your C3 unit looks good. Do you see any problem with the top mount cantilevered over the top strength wise . I think the bottom front mount will keep the twisting up and down in check.
Your 9 inch ford do you have any idea of how wide it was axle flange to axle flange?
