  #24 (permalink)
Old 06-30-2019, 01:27 PM
Tjd Tjd is offline
Mark
you’re correct the front pinion mount takes care of the rotational torque and the top piece connecting the two mounting tubes there is no clearance problem in the 289 chassis
As I remember the 9” did have tight clearance on the top because I use the cut down 9” housing which has a greater OD than the C3. Do not remember the width of the 9” it was wider and a ***** to get it in the 289 chassis. I made the notches on the inside of the main rail tubes little longer and deeper. Remember I did this almost 40 years ago!
Greg
Spicer half shaft will Bolt on just like the original Corvette Half shift with the correct
u joint. Do not remember which stub shaft I used.
Tom
