Old 07-03-2019, 10:53 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by hauss View Post
Funny I have never even thought about low oil temps and personally, I would welcome low oil temps. Just use the proper weight oil your builder recommends . It is my thought that you guys are being like women worrying about nothing.
Well, not to be rude, but you're wrong.
Oil has an operating range. The upper range is pretty well known. The lower range is not well known. Some say it's as high as 200* or so. But 180* seems to be about the minimum.
Studies done in the arctic show that engines running less than 160* show accelerated cylinder wall wear.
Remember that street oil has two viscosity ranges, like 5W-40. When the oil is cold, the viscosity is low and the oil is "thin". Do you really want to be driving around with an oil that thin? Unless you're making a qualifying run, you do not.
Also, the additive packages are designed to operate at certain temperatures. If you're not in that range, the additives don't work like they're supposed to.
Some people think that if the oil temp is <212*, the water collected in the engine will not evaporate. Which is ridiculous. If that were true, your kitchen floor would never be dry. Just remember that the lower the temps are, the longer it takes for that to happen.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
