Old 07-05-2019, 01:03 AM
moore_rb's Avatar
moore_rb moore_rb is offline
Cobra Make, Engine: All original, with Chevy engine since 1964
Originally Posted by joyridin' View Post
The C3 rear ends were just GM corporate 10 bolt rear ends. If you had a big block, they added bigger axles and an Auburn LSD, but it was still a GM 10-bolt. If you have over about 550 hp, even with the Auburn LSD, they will not hold up. Most Corvette owners with a decent amount of horsepower have done a 12 bolt conversion using the 10 bolt housing. It takes some machine work to get it to work, but now you are set for 1000 hp.
This viewpoint is based mainly on the lazy language used in Internet forums. No C2 or C3 Corvette's rear end was a 10 bolt, nor are any of the parts interchangeable with a 10 bolt.
but since the Corvette's rear diff case was held on with 10 bolts... well, there you go... It's a 10 bolt.
The first C2/C3 diff was offered with the 1963 Corvette. Every single one of them from 63 to 82 used a 8.125 inch ring gear, and a Pinion with a 2.125 inch bearing shaft.
The first Corporate 10-bolt differential was offered in 1970 (7 years later) and used a 7 inch ring gear and a 1.75 inch Pinion bearing shaft.
In reality, the Corvette's rear diff design is slightly similar to the later, stronger 8 inch 10 Bolt diffs, but it can also be said that the Corvette diff (and the later 10 bolts) were effectively a scaled down 12 bolt diff, with a shorter pinion shaft, and a 1/4 inch smaller ring gear.
The ony way you are going to break a well built C2 or C3 cast iron diff is if you are dumping 1000+ lbft of torque through it with 33 inch drag slicks.
on street tires, even 1000HP is going to light the tires (especially on a 2500 pound car) long before any diff pieces start breaking...
- Robert
