Old 07-08-2019, 09:50 AM
cycleguy55's Avatar
Originally Posted by tortuga View Post
It sure seems like there’s a lot of oil up on the baffles in the valve covers...just thinking that maybe the deeper stroker crank is whipping up the oil? The stroke is 4” which means the CENTERS of the big ends are 2” below the crank CL, which on a Windsor is right at the bottom of the block right? Wondering How far down do the ends of the con rods and counter weights go...
Steve H
SPF 1764
Given the separation and all the metal between the crankcase and valve covers, how would a crankshaft whipping oil be visible in the valve cover baffles?
IMO oil in the cylinder heads and valve covers is a result of oil pressure and volume. Once the oil gets pumped up there through the pushrods the rocker arms will spray it everywhere. Normal.
Brian
