Old 07-10-2019, 09:47 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by Andrewyoung78 View Post
my clutch slave dump all the fluid out and after replacement and bleed the slave, the clutch grab almost at the top and clutch slip under load in third gear. It doesn't appeal to have any more bubble in the system. What else I should look at. Thanks.
Sounds more like worn out clutch plate or weak pressure plate.
Internal or external slave cylinder?
Gary
