Thread: Hi.
Old 07-13-2019, 03:27 PM
t walgamuth's Avatar
t walgamuth t walgamuth is offline
Yesterday I found the clutch slipping in the taller gears. Drat! Historically I have been pretty easy on clutches so I am not sure why it is slipping. So today I put it up on jacks on one side so I could look at the bottom of the bell housing for oil dripping. I saw none. I also adjusted some free play into the pedal which seemed possibly too tight. After that I test drove it and found it still slipping so next step is probably dropping the transmission.
I also pulled a front and rear wheel and got all the info from the pads.
The pucks in front are 1 7/8" The rears are 1.5"d. four pucks per rotor. Front rotor is 12" rear 11.5 IIRC. 1.25" wide ventilated rotor front and .75 vented in rear.
