Thanks guys,
The car isn't running yet, is on my lift with the wheels off. (been working on the brakes).
I put the transmission in gear, pushed in the clutch and tried the get the rear hubs to move.
They won't move with the clutch engaged. From what I can tell, the slave is moving in and out over an inch.
The clutch pedal doesn't feel right to me, so I'm going to re-bleed the clutch master and slave and see if that helps.
I'm reasonably sure the pressure plate, disc and TO bearing were installed correctly.
Jim
