Old 07-16-2019, 11:54 AM
cycleguy55's Avatar
Originally Posted by w-lewis View Post
I believe oil pan capacity is 9qts. I only drove it around the block to check for leaks. Hopefully, as you suggest, pressure will be a bit lower when fully warmed up.
I'm not running a SBF, but my cold start oil pressure at fast idle (~1500 RPM) with 5W30 is 80 PSI. Hot oil pressure at idle (~750 RPM) is 30 PSI. 2500 RPM hot is about 40-45 PSI. Temperature makes a big difference.
Brian
