Old 07-22-2019, 08:49 AM
H-Rod H-Rod is offline
Cobra Make, Engine: Antique & Collectibles, Forte 427 SB, TKO 600
Originally Posted by spdbrake View Post
If you do decide to use a hole saw. Once the pilot tip is thru run the drill in reverse while you cut thru the Gel-coat to help eliminate chipping. Then switch back to normal R/H drilling rotation. As others have said, its good idea to go to backside and score the hole with the the bit to prevent a lot of final hole blowout chipping.
All the round holes I drilled in my car were with a holesaw spun in reverse.
Drill your pilot hole (in reverse) then use that as a guide for the drill in the hole saw.
I also laid down some painters tape while I did this.
No chipping, cracking or anything.
If you think drilling for the hood latches is a booger, wait til you drill for the roll bar.
