Old 07-28-2019, 02:13 PM
saltshaker saltshaker is offline
Cobra Make, Engine: Contemporary Cobra
Default Engine
You need to wait till the body is on with doors hood etc and wheels are on sitting on the ground. Set your shocks and adjust body height...now set your pinion angle. You should be able to use a standard transmission mount. Also, if you have adjustable lower control mounts make sure your wheel base is 90 inches ...Very important
Jon
The Impossible Only Takes A Little Longer
