Thread: bronze gears
Old 07-30-2019, 11:44 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Originally Posted by hauss View Post
Ok now for the real question if not sure what cam is made of what gear would be the safest to install.Keep in mind I do not mind working on my car if it will make it last.I already change oil every 3 months or 2000 miles. yes I know that is crazy but it helps me sleep at night. Also it does see 6200 rpms quite often.For some reason I just can not help it.
With a roller camshaft, I bet your cam is steel.
With each oil change, you can pull the distributor, and check the gear wear, and replace as necessary.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
