Thread: bronze gears
  #60 (permalink)
Old 08-03-2019, 06:01 AM
undy's Avatar
undy undy is offline
Originally Posted by Dwight View Post
that brings up another point we can discuss.
FL1HP oil filter Relief Valve Open (psi): 22 psi
FL1A oil filter Relief Valve Open (psi): 11-14 psi
how much of the oil is filtered each time it passes through the filter?
How many times would 5 qts of oil have to pass through the filter for all of it to be filtered at least one time?
Those pressures you list are differential pressures between the inlet and filter outlet, not your regular oil pressure. They are supposed to relieve if your filter becomes clogged. That being said, you will filter 100% of the oil as long as your oil filter doesn't become clogged (to the point of your listed differential pressures).
Too many toys?? never!
