Thread: bronze gears
Old 08-05-2019, 08:14 AM
hauss's Avatar
hauss hauss is offline
Cobra Make, Engine: 427 manowar forged crank roller rockers . BIG CAM.
Originally Posted by wolf k View Post
I brought this up earlier, and it is the practical fact that you can only replace the gear once. This is because you have to drill a new roll pin hole when installing a new gear. Like Brent said, it is nearly impossible to line up the hole in the the new gear with the existing hole in the shaft. Even if you could, that does not guarantee that the gear positioning will be correct.
Get it close as you can then ,retime with light. Really not that big of deal provided,you have a timing light and remember your original settings.
