Old 08-11-2019, 12:30 PM
twobjshelbys's Avatar
twobjshelbys twobjshelbys is offline
Originally Posted by jhv48 View Post
Before you decide on a coyote engine, do a search here and read about all the pros and cons. I believe installation and setup is going to shoot your budget.
Heed this, not as advice but as a warning! Before you go down the Coyote path be aware that your engine compartment will likely NOT be compatible without modifications to the internal structure and footbox changes. Unless you are an experienced fabricator your cost to make the changes will cost you money, and in the end, you won't recover your costs in resale. If you want a Coyote buy a Mustang.
Tony
CSX4005LA
