Old 08-12-2019, 06:03 AM
bobcowan's Avatar
bobcowan bobcowan is offline
The E series cams have the same base circle as a stock cam. Lifters (followers) and push rods can be re-used.
To swap the roller followers, you need to remove the heads. BUT, for a cam change, you can pull them up and hold them with a binder clip.
You'll need to remove valve covers, intake manifold, water pump, and front cover.
Be sure to drain the block well, or you'll get water in the oil pan.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
