Old 08-12-2019, 05:38 PM
saki302's Avatar
saki302 saki302 is offline
Cobra Make, Engine: Superformance Mk3, Roush 427
Default Recommendation for clutch slave tension setup
Hello,
(figured out the clutch hydraulic line- I'm ordering Earl's hose and fittings, do it right)
How much tension do you set on the clutch fork from the slave cylinder?
The slave has a spring in it- do you set it so there is a little play before the hydraulic movement engages, or no play? There isn't any fluid in the cylinder yet (not until fittings and hose comes)
I noticed some slop (up down) in the clutch fork until you put pressure on it. (The TB is installed correctly on the fork )
Thanks!
-Dave
