Old 08-13-2019, 01:25 PM
nathanmargolis nathanmargolis is offline
Default Oil Pan Gasket
Went through this with a Backdraft and used the Fel-Pro blue one piece gasket and highly recommend. Like anything else, take you time, make sure the gasket seats properly, torque in a pattern, and do use a gasket sealant on the front and back. Order it from RockAuto and save money.
First time I did this, it was at a friend's house on a lift, rushed through it, and had leaks. Second time at home on jack stands and did it methodically. All is good.
Backdrafts- oil pan comes off like a old automatic transmission pan by undoing the bolts and not undoing anything else. There are no cross members, starters, or exhaust in the way. Pan came off in about 20 minutes.
Good luck.
