Can you post a link to a video please Paul?
While the noise is there, does it go away if you just lean on the shifter a fraction?
In neutral, all gears on the mainshaft are rolling over at their respective speeds.
If this was a particular gear needle bearing or thrust race, the noise would be there in every gear, except the gear causing the noise.
Gary
