Old 09-03-2019, 07:07 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Originally Posted by HighPlainsDrifter View Post
The msd puts out multiple sparks probably starts 10 to 15 degrees early. I would try moving the distributor to retard the timing 6 or 8 degrees and see if that helps. or you could try the timing at over 3000 rpm for total timing as the multi spark is only under 3 K then only 1 spark. 34 to 36* total depending on your octane in fuel.
Perry
MSD's first spark occurs at the first correct timing point, the successive sparks occur AFTER, during the following 20 degrees of crank rotation.
If the first spark occurred early, the engine would ping.
An ignition timing light picks up the first spark regardless, so sparks could not be occurring early.
So to the OP, please verify your timing as mentioned above by others, with a non-dial back timing light.
If the engine truly feels like 250 versus 500, there is something seriously wrong in your installation.
Either the timing is retarded from where it should be, 18 - 36, or the fuel supply can't keep up.
Does it go well in 1st gear, then lay down, or not at all?
Gary
