Old 09-08-2019, 03:50 PM
Jim Coleman's Avatar
Jim Coleman Jim Coleman is offline
Cobra Make, Engine: 1980 Arntz, 350 'Vette & Muncie, & Jag rear
Perry,
I first tried using a double circuit GM switch, but went to the Speedway single circuit switch because the instructions showed it in use.
Cruisin:
Checking the harness wires that go to the turn signal switch with 12V (both flashers pulled):
Blue RF Turn signal & indicator - light & indicator work
Lt Blue LF Turn signal & indicator - light and indicator work
Yellow Left rear Turn signal - all 4 and the license plate light lights up
Green Right rear Turn signal - all 4 and the license plate light lights up
Note: both of these will flash if the turn signal flasher is installed.
Not sure where to go from here...…
Thanks,
Jim
