Old 09-08-2019, 04:33 PM
spdbrake spdbrake is offline
Jim,
Did you run a ground to each light or are are they daisy-chained (Series circuit)?
If they are you may have Christmas lights.
If so, if you remove 1-2 bulbs the remaining bulbs will be brighter, but most likely one bulb removed will break the circuit.
Also ensure you have the correct PN turn signal bulb and Brake/running lights bulbs and they are not swapped.
It almost seems like your rear lights, turn signals and license plate already have power to them and the turn signal switch is supplying a ground.
The only other thing I can think of right now is your definition of green,pink red, etc... may be off. You may want to start over or get input from another set of eyes. I find that is the most helpful as most of the time the answer or mistake on my part is staring me in the face. I just can't see it.
