Old 09-10-2019, 05:20 AM
Jim Coleman's Avatar
Jim Coleman Jim Coleman is offline
Cobra Make, Engine: 1980 Arntz, 350 'Vette & Muncie, & Jag rear
I will pull the headlights (halogen) and see...
Here's what Autowire says:
My turn signals work, and my lights work, but when my lights are on, my turn signals will not work.
This is a classic bad ground problem.The problem is that the light sockets themselves are not grounded properly or at all. For anything electrical to work properly, you must have two (2) things, a 12-volt feed and a ground. The bulb usually picks up a ground through the case of the bulb, but in this instance it’s picking up an improper feedback ground through the opposite wire in the light socket itself. The reason the turn signals quit working when the lights are on, is that a 12-volt signal is now being sent down the opposite wire, which was acting as a ground before. Once the lights are turned off, everything will work fine again.
Solution: Be sure that whenever your lamp is grounded, you have a good known chassis ground. This usually involved scraping paint or rust from the mounting surface and, in extreme cases, running a separate ground wire to the lamp assembly itself.
I thought I had the ground problem solved. I ran wires to the negative battery post, and then ran wires to each light. Will have to recheck and see what happened.
