Old 09-10-2019, 02:57 PM
MKS427's Avatar
MKS427 MKS427 is offline
Cobra Make, Engine: FFR MkIV 427
Originally Posted by caesarmascetti View Post
for what it's worth from everything Ive read you dont need an airgap, the current Preformer RPM works just as well and offers more clearance. I would add a spacer between the carb and intake a phenolic spacer (keeps the carb insulated from heat). As for a carb, Quickfuel VS 750
my two cents
interesting read
https://www.hotrod.com/articles/hrdp...pm-vs-air-gap/
Hot Rod did not test at operating temperatures, in other words not real world application. They stated they did not data log temps.
Both manifolds on a cold engine would have similar numbers. However as the engines get to full operating temp, the air gap should deliver a cooler fuel charge. I would not save the $28.
