Old 09-18-2019, 08:58 PM
Manx69 Manx69 is offline
Thank you.
There is no voltage to coil nor the relay that activates the computer. Ford wiring harness shows that as a single circuit directly off of the ignition switch with a fusible link in the line.
I don’t know where to start looking for the problem but it clearly resides between the ignition switch and coil. I just don’t know how to locate where and follow that wire.
