Old 09-23-2019, 12:01 PM
cycleguy55's Avatar
Originally Posted by spdbrake View Post
From the Comp Cams PDF: "As opposed to bronze gears, melonized versions are less wear-prone and feature better timing accuracy and higher strength than any other universally compatible distributor gear option. The greater wear resistance and higher precision of COMP CamsŪ Melonized Gears also provide less spark scatter (more accurate timing) than is possible with a bronze gear."
You'll note they're comparing their Melonized gears to to universal and bronze gear options - not to iron and steel options. If Comp Cams believed Melonized gears were better than iron on iron and steel on steel, don't you think they'd make that clear? I believe they know full well Melonized is NOT better than properly matching iron gears to iron camshafts, and steel gears to steel camshafts.
Accept or reject expert opinion from engine builders like Brent but, as always, "your mileage may vary" (literally and figuratively).
You can read more about Melonizing here: https://en.wikipedia.org/wiki/Ferritic_nitrocarburizing
Brian
