Old 06-09-2002, 05:47 AM
ron427 ron427 is offline
Sounds like you may have damage to starter drive and/or
flywheel teeth. Remove starter and inspect drive gear. rotate engine one full turn and look for damage on flywheel ( will
probably have wear on three equally spaced sections) Suggest you first rotate the engine about 1/4 turn by hand and attempt to restart. This will possibly confirm what I suspect. Good luck. Ron
