Old 10-01-2019, 10:07 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
Backfires can still be wrong ignition timing out the exhaust.
Either 360 crank degrees out, or leads wrong direction on cap.
Verify 10 BTDC, with a spark plug out feeling for compression as you rotate towards TDC.
Remove distributor, refit with rotor where you want NO.1.
Gary
