Old 06-09-2002, 08:25 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Default How new is the starter install? Who did the work?
If the starter teeth were not aligned correctly with the flywheel teeth to "start" with, then it may have caused premature bearing failure in the starter. Getting it just right with all the variables of flywheel and starter combos can be tricky.
But if you have a lot of miles on the install, this is an unlikely cause of the failure.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
